Старый 03.07.2011, 17:57   #76
dancer_st
Аватар для dancer_st
Автомобиль: BMW e36 sedan
Поблагодарили 87 раз(а) в 38 сообщениях
dancer_st Репутация выше среднегоdancer_st Репутация выше среднегоdancer_st Репутация выше среднегоdancer_st Репутация выше среднего
Дало прирост мощности в диапозоне 3500-5000
Modifying the M42 318iS Author: Stuart McHenry
This is a compilation of things that are necessary to get real performance out of the M42 engine that you use in a street/auto-x/mild track use car. These are items that will improve the cars performance and not sacrifice any low-end torque, which you want for street driving. These are all pretty much "bolt-on" mods, using the engines factory internals. If you want your 318iS to really fly on the street, these are the things you need to do:
Computer chip - This is a very basic and inexpensive modification for your car. Chips usually run about $200-$300 and are very easy to install. A chip on a stock M42 will bump the horsepower to about 145 (from 135) at the peak. The low-end torque is increased as well to improve everyday drivability. Though the real improvement comes at the top end; the chip widely increases the power band on the M42, from 4600-6000 to 4500-6700. I recommend Jim Conforti chips, as they are unarguably the best on the market for this motor, at a good price as well. On a side note, you will find the M42 makes a very distinctive "howl" from 6700-7200 rpm that reminds you that you’re driving an honest-to-God BMW.
Flywheel - A major problem with the M42 was that it had BMW’s 'dual-mass’ flywheel; yes, it weighs almost twice as much as a 325i flywheel (as the name would suggest), at 28.5 pounds. This is a big problem and absolutely kills 1st and 2nd gear acceleration. Ever wondered why your 318iS’s 0-60 was so slow? Well, the flywheel is one of the reasons. There are 3 options to fix this: 1) use a 325i flywheel/clutch or 2) buy an aluminum flywheel for your M42's clutch, and 3) an aluminum flywheel for using the 325i clutch. Buying an aluminum flywheel for the M42 runs about $500-700 but is very light, and requires no modification to be fitted. M42 aluminum flywheels are about 12 pounds, and 325i aluminum fly's are about 8 pounds. The 325i flywheel requires a few other modifications to be fitted in the 318iS. Here’s what you need: 325i flywheel, 325i clutch, 325i pressure plate, 325i drive-pinion for the starter motor, and a ‘78-’83 323 throw-out bearing. Replace all these with the 318iS parts and it bolts right together. After all is said and done, your 318iS will have a LOT better acceleration in the first few gears, and deceleration will take place much quicker, which helps on the street and in the auto-x.
Rear end gear - The 318iS is equipped with a 4.10 limited slip from the factory, but you can do better. The desired gears out there are the 4.27 and the 4.45. You will find the 4.27 in E30 318i convertible 5 speed’s and the 4.45 is in E36 318i automatics. The 4.45 is a wicked, wicked street gear but will stick your RPM way up there on the highway. The 4.27 is a good compromise of performance and everyday use. It should be known that to make a 4.45 work, you have to swap the gearset into your E30’s differential, or find an automatic 318ti, which has a 4.45 and also has trailing arm rear suspension! So the E36 318ti 4.45 bolts right onto an E30, though finding an automatic 318ti with LSD may be difficult.
Adjust the cam timing - You know how on the E30 M3 you have to buy a $300 kit with adjustable cam sprockets to tune your cam timing? Not on the 318iS! The M42 is equipped with tunable cam sprockets from the factory. So pull your Cosmoline covered valve cover off and with the proper tools you can tweak your intake and exhaust cams up to 6 degrees +/- to provide more top end horsepower or more low end torque. See, you don’t have to blow a grand on a set of Schrick cams to make your M42’s cams a little hotter. The best setup is to adjust the intake cam to 5 degrees (advanced) and leave the exhaust cam alone. I would recommend having a shop do this work.
Muffler - The 318iS is equipped with a very free flowing exhaust manifold and center section with 2.25" stainless piping. The bottleneck in the system is the muffler. Thee are a few options for this. The first is a cat-back system, which replaces the piping and boxes behind the catalytic converter. Supersprint makes an excellent cat-back system that runs about $400. You can also simply replace the muffler. There are a variety of mufflers on the market but there is one that is very inexpensive, sounds great (not too loud, but throaty), and fits an E30 very well - it is made by Walker-Dynamax and is called the "Super-Turbo" muffler. It is available from Summit Racing at the price of about $40. We have had great success with these mufflers, and even use them in 3" size on our E30/S50 cars.
Intake system - The 318iS stock airbox works well, but a cone filter setup works better, but only if you have a well-built heatshield! Get a large K&N setup with the AFM adapter and all. Go to Home Depot, buy some Reflectex and build a "cool-air" system by cutting and fitting a heatshield. It is worth it in the end. While you are working on the intake, get the secondary plate of your throttle-body bored out 3mm to 57mm. This will make a difference.
Summary: You will find that with a little time, a little cash, and a little elbow grease, you can tune your 318iS to really perform. William Zubrick's 318is with a properly built intake, Supersprint cat-back, and Jim Conforti chip puts 131hp to the wheels on a chassis dynomometer. Enjoy!
318i E36/M42 LIM
http://tankionline.com/#friend=911bdf239
dancer_st вне форума   Ответить с цитированием
Старый 03.07.2011, 18:29   #77
oldboy
Аватар для oldboy
Автомобиль: e39 m54b25, suomalainen m3 s50b32
oldboy Нейтральная репутация
ух ты! редко встретишь человека с прямыми руками, головой и с, можно сказать, безупречным чувством вкуса. спасибо.
p.s. образование, наверно, из области искусств?
мы ведь едем в пацанмобиле, нас охраняют иисус и мария
oldboy вне форума   Ответить с цитированием
Старый 03.07.2011, 19:01   #78
dancer_st
Сообщение от oldboy Посмотреть сообщение
p.s. образование, наверное, из области искусств?
Да...)
318i E36/M42 LIM
Старый 04.07.2011, 11:07   #79
Ася_Асина
Аватар для Ася_Асина
Автомобиль: BMW 3er coupe
Сказал(а) спасибо: 22
Поблагодарили 24 раз(а) в 23 сообщениях
Ася_Асина Нейтральная репутация
приехал подстаканничек, спасибо ))))
тока вот вопрос..а стаканы в нем держатся??? еще не прикрутила..что-то кажется мне места там маловато...
PS КУПЛЮ МОТОР м42/ м44
я вообще люблю людей, как жаль, что с 1861 года их нельзя дарить
Ася_Асина вне форума   Ответить с цитированием
Старый 06.07.2011, 01:19   #80
dancer_st
Сообщение от Ася_Асина Посмотреть сообщение
Большая кола с макдональдса не влазит, все остальные стаканы помещаются и держатся нормально полными.... если конечно не топить в пол с перекрёстка
318i E36/M42 LIM
Старый 17.07.2011, 22:12   #81
dancer_st
Приехала посылочка из Москвы ))
Спасибо большое jek@
Нашёл кнопки на руль под телефон... были облезшие, перекрасил.
318i E36/M42 LIM
Старый 14.08.2011, 22:14   #82
dancer_st
Просто фото....
318i E36/M42 LIM
Старый 19.10.2011, 23:06   #83
dancer_st
318i E36/M42 LIM
Последний раз редактировалось dancer_st; 20.10.2011 в 11:06.
Старый 19.10.2011, 23:24   #84
Enot
Аватар для Enot
Сказал(а) спасибо: 219
Вес репутации: 80
а как кнопки перекрашивал, раскажи процес и про материалы
Старый 19.10.2011, 23:27   #85
dancer_st
Кстати, позавчера опять перекрасил.... сейчас намного лучше выглядит.
выкину фотку завтра
если есть сколы краски на треугольниках, то нужно под ноль наждачкой снимать старый слой, если сколов нет, то просто мелким наждаком матуй, а потом крась 2-мя слоями из балончика! (так намного меньше шагрень).
318i E36/M42 LIM
Старый 20.10.2011, 23:09   #86
Enot
Аватар для Enot
Вес репутации: 80
а ты красил треугольники, я подумал ты решил проблему протертой краски на самих кнопках(((( все равно спасибо обязательно обновлю их
Старый 20.10.2011, 23:10   #87
dancer_st
Проблему потёртых кнопок тоже решил
нашёл другие в лучшем состоянии
318i E36/M42 LIM
Старый 21.10.2011, 13:00   #88
Enot
Аватар для Enot
Вес репутации: 80
Оригинально))))) Что еще в планах на будущее?
Старый 21.10.2011, 13:39   #89
dancer_st
Вчера сверлил отверстия для парков в молдингах переднего М-бампера...
кстати старые молдинги с днёздами под датчики для обычного бампера продаются, вместе с мартёрами бампера (они тоже подрезаны)
из ближайшего
в планах электро-салон
электро-шторка
накладки порогов М
318i E36/M42 LIM
Старый 10.11.2011, 21:07   #90
bmw747
Автомобиль: e36 318is coupe 1994
bmw747 Нейтральная репутация
Зачётная машинка у тебя. Видя твой салон сердце замирает...
bmw747 вне форума   Ответить с цитированием
Старый 10.11.2011, 21:44   #91
dancer_st
Сообщение от bmw747 Посмотреть сообщение
Спасибо!
Добавлено через 42 секунды
Недавно было изготовлено вот что....
Добавлено через 25 минут
и вот ещё что
318i E36/M42 LIM
Старый 11.11.2011, 00:07   #92
Поблагодарили 434 раз(а) в 276 сообщениях
Вес репутации: 120
Последнее - хэнд мэйд или дооснащение какое-нибудь? Очень понравилось!!!
а про площадку не понял... Зачем?
ПС: руль твой поставил - радует Осталось кнопачки подрубить
Старый 11.11.2011, 00:10   #93
dancer_st
Подсветка ручек - хэнд мейд )) из оригинальных запчастей от Е38-39 (лампа накаливания + оптоволоконный кабель)
А площадка - это чтобы на моём моторе (М42) поставить катушки вместо высоковольтных проводов.
318i E36/M42 LIM
Старый 11.11.2011, 00:19   #94
Вес репутации: 120
dancer_st, Давай тогда технологию изготовления подсветочки расскажи! Плиз тоже замучу
Добавлено через 34 секунды
Хотябы в 2х-3х словах
Старый 11.11.2011, 00:20   #95
dancer_st
в 2-ух словах уже написал ))))
а вообще через месяц, может раньше будет отдельный фотоотчёт по подсветке ручек.
318i E36/M42 LIM
Старый 11.11.2011, 09:34   #96
Вес репутации: 120
dancer_st, ок! Ждемс!
Старый 27.11.2011, 02:04   #97
MaxG
Аватар для MaxG
Автомобиль: 323i 97г
Сказал(а) спасибо: 81
MaxG Нейтральная репутация
http://www.bmwclub.by/forum/index.php?/topic/89949/
323i 97
MaxG вне форума   Ответить с цитированием
Старый 09.01.2012, 18:59   #98
Pavlik
Аватар для Pavlik
Поблагодарили 24 раз(а) в 22 сообщениях
Pavlik Нейтральная репутация
dancer_st, а что кнопочка PDC дефицит?! знаю где на разборке лежит за 300р...
E36 compact m43b19TU 2000
E46 sedan m54b22 2004
Pavlik вне форума   Ответить с цитированием
Старый 09.01.2012, 19:00   #99
dancer_st
Сообщение от Pavlik Посмотреть сообщение
ага. Пришли мне её в Минск, пожалуйста!
318i E36/M42 LIM
Старый 11.01.2012, 11:57   #100
Boris_off
Аватар для Boris_off
Сказал(а) спасибо: 220
Вес репутации: 131
dancer_st, тебе,вопросец,у тебя есть схема подключения заднего PDC?желательно бы распиновку проводов с фишки от которой провода идут в переднюю часть авто,
п.с.спасибо за схему ту что на мыло скидывал
BMW e36 coupe m50b20 ==> m52b25 ==> m50b30 АКПП+LSD 250Нр и е39 523i АКПП и е23 без двс и кп
Текущее время: 02:53. Часовой пояс GMT +3.
